Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Issues With Mapped Properties
0 REPLIES 0
Message 1 of 1
262 Views, 0 Replies
Hello All,
There seems to be a number of posts similar to my issue, but none that are a direct match.
So let me begin -
I have a development server that I am currently performing a Proof of Concept for one of our business units for the implementation of Vault Pro 2012.
I have a lifecycle -
DRAFT - PENDING VERIFICATION - PENDING APPROVAL - RELEASED
Each State change has an action to 'Synchronise properties and update view using Job Server' -
I have UDPs that map from Vault to both my IDWs and DWGs with no issue.
However, I utilise the 'State (Historical)' property to populate a Drawing State property to indiacte the Lifecycle State -
For IDWs this process works very well, when a IDW is added to Vault and the properties set, the Drawing State is populated with DRAFT. Also, when a document is transitioned from DRAFT to PENDING VERIFICATION my Job Server updates my properties and creates a DWF.
However, for my DWGs this is not the case. When a new DWG is added to Vault the Document State is populated with DRAFT. But, when transitioned from DRAFT to PENDING VERIFICATION though the Document State is not updated and I also do not get an updated view. I also have this Non Compliant error -
I can 'Check Out' the DWG and perform an Update Properties but am concerned that it is not functioning for DWGs as it does for IDWs.
Am I missing a glaring mistake?
All help appreciated.
Regards
Stephen
0 REPLIES 0
