Vault General
Distinguished Contributor
anderson51
Message 1 of 2 (106 Views)
Accepted Solution
Is Field Text Searchable?
106 Views, 1 Replies
02-08-2013 02:19 PM
We have typically only filled out Iproperties and used those as the searchable fields in vault. ls it possible to search the "property fields" in Field Text?
*Expert Elite*
cbenner
Message 2 of 2 (87 Views)
Re: Is Field Text Searchable?
02-11-2013 07:55 AM in reply to: anderson51
If I understand the question right, yes.  But it may depend on what version and level of Vault you are using.  Next to the search window you should see a small circle with 2 arrows in it.
If you select this it will open an enhanced search.  From here you can add properties that you would like to search.
Hope this helps.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
