Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Is Field Text Searchable?
1 REPLY 1
anderson51
297 Views, 1 Reply
We have typically only filled out Iproperties and used those as the searchable fields in vault. ls it possible to search the "property fields" in Field Text?
1 REPLY 1
cbenner
in reply to: anderson51
If I understand the question right, yes.  But it may depend on what version and level of Vault you are using.  Next to the search window you should see a small circle with 2 arrows in it.
If you select this it will open an enhanced search.  From here you can add properties that you would like to search.
Hope this helps.
