Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Inventor .idw/.ipt property compliance and UDP "Rev Number"
0 REPLIES 0
Message 1 of 1
527 Views, 0 Replies
We've got problem with UDP "Rev Number" when we want cooperate this UDP with system property
"Revision". Vault report a non-compliant for .idw file.
Configuration (mapping) UDP "Rev Number" and system property"Revision" is here:
User defined property "Rev Number":
Provider               File Property    Type    Classification             Mapping            Create
Inventor               Rev Number    Text    Standard            Vault <-> Document    Yes
Inventor DWG     Rev Number     Text    Standard            Vault <-> Document    Yes
AutoCAD             Rev Number    Text    Standard             Vault <-> Document    Yes
UDP "Rev Number" has declared categories as well.
System property "Revision":
Inventor                Rev Number    Text     Standard               Vault -> Document    No
Inventor DWG       Rev Number    Text    Standard                Vault -> Document    No
When we Check in new .ipt with .idw from Inventor to Vault there is this situation:
.ipt has Property compliance - Compliant and "Rev Number" is empty, "Revision" is "0"
.idw has Property compliance - Noncompliant equivalence and "Rev Number" is 1 (one) !!
    "Revision" is "0".
This is problem for work with lifecycle when Vault changes lifecycle  state and
controls revisions. There Property compliance could be Compliant, it's nice behaviour.
I've read Chris Benner's report "Inventor DWG property compliance" 09-11-2013 here at forums.
But I can't to find the solution. I've tried change the mapping "Rev Number"configuration
above without good result.
I think cooperation UDP "Rev Number" and system "Revision", I mean interchange argument,
is not possible if you want to use only Vault skills.
Unfurtunately elementary advice probably is - don't use UDP "Rev Number" and mapping for
System property "Revision".
Do you happen to have some better practices with it, if any.
Thank you for any help you can provide.
Peter
0 REPLIES 0
