Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Inventor Task scheduler issues when working with Vault functions
2 REPLIES 2
stapprich
588 Views, 2 Replies
I am currently in the middle of a Vault migration task (basic level) of 65k files using the task scheduler and I must say I would rather shoot myself in the foot!!
I am noticing that the check-in process is taking FOREVER (close to 48 hours for 4k files). I assume this is bc of the visualization file creation with a base level vault but was hoping there is a way to speed up the process (memory leak or temp files slowing it up?) If I run a task of 500 files then the task will run in about 1hr 30 min but anything over 1k files seems to really kill the process.
Also, how come I can not select multiple files when the vault function is being used? this makes it very tough for me to break the task up if I have to select 500-600 dwg's manually!!
Help Autodesk....what can be done to make Task scheduler more useful!?!
2 REPLIES 2
BLHDrafting
in reply to: stapprich
Hi stapprich.
Having gone through 3 migrations I feel your pain. Task Scheduler needs a major overhaul. Through trial and error I have figured out that 500 files at a time is about the maximum my setup can handle without excessively long delays. And also doing ipt's first, then iam's then idw's seems to help. Why? Buggered if I know but it does.
Whether good or bad (another discussion) we have Vault basic with 2 projects, Library and Projects. I only migrate the Library items. The Project items get migrated when opening the iam/ipt/idw. Is this the best method? Again buggered if I know but it works in my situation.
Next week we are updating to 2013 and Vault Workgroup with which I intend to go to 1 project and use the lifecycle states to lock down what I consider to be Library items.
Hang in there with TS. It is a pain but is really the only effective method of batch processing these items without going down the path of opening each ipt/iam/idw in Inventor and doing the migration there!
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
stapprich
BH, Thanks for the reassurance that I am not crazy. I have found the same outcome of trying to migrate more than 500 files at a time. I recommended that the migration process take place during a revision but due to custom programming, the files need to be the latest version.
Well, I guess a folder at a time is the only way to do this meaning I can not multi-select files from the Vault to be migrated....GGRRRRR!!!
