Vault General
Message 1 of 5 (350 Views)
Inventor LT and Vault Pro
350 Views, 4 Replies
03-07-2012 08:06 PM
I have a cusotmer that is trying to use Inventor LT and Vault but we are having issues with setting the local workspace. Currently, the work path is going to %userprofile%/Documents/Vault/Designs but the actual workspace for Vault should be C:/Vault_local/Designs.
I have noticed that I can not change the Inv LT work path unless I unload the EDM Vault add-in. However, after unloading the add-in, changing the work path and then reloading the EDM add-in...the work path will go right back to Documents/Designs.
Is there anyway to set the Vault workspace for Inventor LT to match the Vault meaning Inventor LT does not use a project file?
Employee
Senthil-Autodesk
Message 2 of 5 (326 Views)
Re: Inventor LT and Vault Pro
03-08-2012 07:01 PM in reply to: stapprich
Unfortunately the answer is NO. As mentioned in the Readme "When using Inventor LT with Vault, the user's workspace is hardcoded to %USERPROFILE%\My Documents\Vault\Designs and mapped to the root folder “$” in Vault. Workspace mapping cannot be changed. "
Senthil Kumar
Sr QA Analyst
Be sure to check out the Vault Help!
Message 3 of 5 (317 Views)
03-09-2012 06:53 AM in reply to: stapprich
I appreciate the response. Can I share a concern?
If we are not able to change the workspace to match the proper file structure, then how does Autodesk recommend we use an add-in with a program that is built on file structure?
Thanks!
Valued Contributor
Message 4 of 5 (227 Views)
02-11-2013 05:24 AM in reply to: stapprich
Hi
We are a multiple application company with different diciplines of cad applications with a set Vault Workgroup with a set folder structure, we recently bought 4 Inventor LT, only to find out its not compatible with our vault folder structure, why then the add in funtion, why hardcode something as simple as a vault add in.. doesnt make sense, and we would have bought 5 more seats, but is thinking twice now before commiting,
Employee
Senthil-Autodesk
Message 5 of 5 (214 Views)
02-11-2013 06:46 PM in reply to: jacoj
We understand your concern. I have forwarded this to the product management to take a look.
Senthil Kumar
Sr QA Analyst
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
