I have been having some issues on some select Inventor DWG's where it doesn't seem like the UDP's are mapping correctly. The attached images shows a non-compliant that is preventing us from releasing the files. I have tried to force the compliant by syncing the properties or editing the property and even with both matching it still gives the compliance error.
A couple other interesting things about these files is that when I open from Vault they want to open in AutoCAD where all our other inventor dwg's open with inventor.
Also, I tried to re-index the file properties on the server and every one of these files we are having issues with shows and indexing error of 'The iFilter for this file extenion could not be loaded.' and the file type is .dwg.
We can work with the files just fine except when we go to release them. If they somehow got corrupt we will just have to remake them but there are quite a few, so I am hoping someone has seen this before and has a solution before we start waisting some time.
Steve
How are you managing the revisions on these? Through Vault? With a lifecycle change? Can you post screen shots of your property mappings?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for the response. We are using vault and lifecycles to control the revisions. The attachment shows how that rev number is mapped. The odd thing is that is only for a handful of files and not all of our inventor dwg's.
Steve
It looks like you have a UDP, "Rev Number" mapped to the same property in Inventor. When you bump revisions using lifecycle on files, it bumps the System property "Revision". How is that property mapped? Perhaps what you need to do is map "Revision" from Vault to File property "Rev Number" (in one direction), and then map the cad property "Rev Number" from file to Vault property "Rev Number"(in the other direction).
That way a revision bump in Vault will push the new rev out to the CAD file when you do "Get Revision" and "Update Properties", and then when it is checked in it should populate the Rev Number in Vault.
Should... big word...
Good luck!
Chris Benner
We do have that UDP mapped back to the system Revision (I should have added this capure as well). I also attached what our typical property field should look like. We are mapping more properties than just the revision that aren't showing up at all either, the revision is just keeping us from releasing the files.
Steve
Ok, (bear in mind I do a LOT of trial and error when it comes to this stuff)... but I think your problem may be that you have both Revision, and Rev Number mapped FROM Vault TO the CAD property. This creates a conflict, so Vault just does nothing. I'd say change Rev Number's mapping so that it goes one way from CAD to Vault, and leave Revision as it is, going from Vault to CAD. See if that makes a difference.
Chris Benner
I switched the CAD to Vault to be unidirectional and reindexed the properties without any change. I can't reproduce this with any new drawings, its only happening on select old ones. I'm thinking this might be one for Autodesk.
Thanks for the suggestions.
Steve
Steve,
Did you ever happen to figure this out? we are having the issue.
Unfortunately we haven't got this issue sorted out. I haven't had the time to bring this to Autodesk and at the moment it is not a pressing issue because the files affected are only a small percentage of our oldest drawings. If I learn more I will be sure to post.
Steve
We made some progress on this issue last week. What we found is these drawings had a old version template and for some reason it was not able to communicate with our current version of Vault.
You can either save these drawings as idws. Once they are converted to idw it reads all the user defined properties in Vault and does not give complience error.
Alternative you can use DWG true view to convert the drawing to later version. (see attached snapshot). Once converted to later version all the user defined properties are read in Vault.
Bhavin
