There are a number of factors that need to be looked at to determine first
the cause, then the fix. In the mean time, in order to get back on track,
you can check a copy of this file back in to the Library folder. Then use
the Replace command in Vault to swap the ipt in the Temp folder with the one
in the Library folder. Please move forward with submitting this to a support
center though, then we can address it.
As a best practice moving forward, do not move files into other folders
simply to work on them. This causes a lot at least two additional
unnecessary versions just to edit library parts. Instead, from my earlier
post, create a "Library Edit" .ipj in the Vault library folder just for
these cases where you need to modify Library parts.
Brian Schanen
Customer Success Engineer, Data Management
Autodesk, Inc.
"ricebrianrice" wrote in message news:5919032@discussion.autodesk.com...
> What other information would you like?
