Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Inv and Cad titleblock properties mapping
5 REPLIES 5
Winks87
372 Views, 5 Replies
Is it possible to have an Inventor custom iproperty (for dwg title field in titleblock) and an Autocad attribute (again, dwg title field in titleblock) mapping to the same field in the Vault?  We have Autocad and Inventor drawings in the same folders in Vault and would like to see common Vault fields displaying the information regardless of Autocad or Inventor.
James Winkler
5 REPLIES 5
cbenner
in reply to: Winks87
PaulMunford
Hi Chris,
Does this work for attributes owned by layouts? or just file properties?
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
cbenner
in reply to: PaulMunford
mikel_martin
in reply to: cbenner
You can map block attributes or file properties.
But if you want to more than one layout in a DWG with different values in each title block you will have to use sheet set manager, which is integrated with Vault.
Mikel Martin
User Experience Architect
Autodesk, Inc.
ryan
in reply to: mikel_martin
Hi Mikel,
  I'm very comfortable with configuring vault to map to autocad attributes; however, I wasn't aware about your comments regarding seperate attribute values via SSM.  I've hardly worked with SSM since most customers I work with are either on Inventor or their ACAD data is in model space; however, I'd like to know how to do this should the need arise - would you have a link (doc or video) or summary of steps to set this up?
 Ryan
Ryan Small
National Team Leader, Data Management and Software Development
SolidCAD, a Cansel Company (an Autodesk Platinum Partner)
www.solidcad.ca
