Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Installing Vault 2014 Professional server onto Windows Server 2012
2 REPLIES 2
Raid.n.t
743 Views, 2 Replies
Hi Everyone,
i am after some help on installing Vault 2014 onto win server 2012,
i have followed the Advanced config guide and i cant get past the pre-checks
-running SQL Standard 2012
ASP.NET precheck is failing
the attached document details what i have done and tried
any help would be apreciated
James
2 REPLIES 2
samuel.seah
in reply to: Raid.n.t
Hi James,
Will you be able to remove the IIS feature and then do a new configuration based on the following?
Samuel
Raid.n.t
in reply to: samuel.seah
Thanks for that,
this has worked with the features you have suggested,
steps to fixing are as follows,
uninstall all iis features,
reboot,
install all features suggested above,
I did run the installation again after this and I still got an error about unable to access static file, another reboot and the system check went through with out a problem.
thanks again
