Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Installing Vault 2014 Professional server onto Windows Server 2012
6 REPLIES 6
herbvegawt
388 Views, 6 Replies
I'm trying to install  Vault 2015 Basic on SQL 2012 server. The problem I have is that the Installation is not recognizing the SQL server. If I create an AUTODESKVAULT instance, the installation requests to be removed because it is an unused database. I cannot add the sa account because it is already there (we have other databases installed). The installation goes through but installs the SQL 2008. How we can install Vault on the existing Database Engine?
Thanks.
6 REPLIES 6
DarrenP
in reply to: herbvegawt
did you follow the advanced config guide?
http://download.autodesk.com/us/vault/2014/2014_Advanced_Config_Guide-2014.pdf
DarrenP
jesseck
If Darren's suggestion (following the guide) doesn't work another direction would be to install with the default SQL 2008 instance and upgrade to 2012 SQL.
herbvegawt
in reply to: jesseck
Jesseck, I'm going to try to upgrade and I will get back to you with the results.
Thanks.
herbvegawt
Is there a written procedure on how to upgrade the Vault database to SQL 2012 and install the software? Thanks.
r.smith1
Hi Herb,
Please find the steps to install and upgrade SQL in the Advanced Configuration Guide
Ron Smith
New Product Introduction Manager
Autodesk, Inc.
sfaz
in reply to: r.smith1
Windows Server 2012
SQL Standard 2012
Vault Basic Edition 2015
Following the advance configuration guide
The Error while trying to add the Vault database to SQL 2012: "the AUTODESKVAULT instance is not in use". The only way to continue is to delete the instance then installs the SQL 2008 espress, which is not what we want.
