We are at stage of wide implementing web-client.
I feel a bit fed up with making each and every new user to print/choose name of our Vault (database) when he/she uses web-client link.
By default the "Vault:" field is filled with "Vault" and of course user who just presses <LogIn> gets message "the referenced vault does not exist" (Vault names are made customizable to be customized, right?).
Is there any way to include Vault Name to web-client link (like it is done for Vault Explorer links)?
To the best of my knowledge this is not possible to create a link an URL including pre-defined values for the login site. However, when the user logs in again the last values should be already populated. It means, he must type the Vault name only once.
Hope it helps.
@Olaf.Górski wrote:Hello,
Hope it helps.
Olaf, this is not always the case, as I have seen the problem as well. If a user logs in on Web Client, and selects the correct Vault name, then does not log in a gain for a while... sometimes it reverts back to the default "Vault" on a subsequent login. Does this require "cookies" for the Client to remember the previous login?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
