Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Import a user from a linux domain
11 REPLIES 11
Message 1 of 12
529 Views, 11 Replies
Hello!
I'm trying to import users from the domain, but show me the message "You must be authenticated to a domain in order to perform this operation" being that I'm already in the domain. It's important to know that the domain is in Linux, Is that  the problem?
thanks!
Tags (3)
11 REPLIES 11
Message 2 of 12
herrerh
Importing a domain user only works with Microsoft Domains and Windows Active Directory.  We have not done any testing on samba/linux implementations of Active Directory or LDAP.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 12
in reply to: herrerh
Ok
Message 4 of 12
aparrow
I get the same error, however I am on a Windows network with Windows AD. Both machines are 2008 Server R2.
Any ideas?
Inventor 2012/2014 Certified Professional
Product/Factory Design Suite 2018
Vault Workgroup & Pro 2018
Dell T7610 - Dual Xeon @ 2.5GHz / 64GB Ram / ATI FirePro W7000 / 512GB SSD & Dual 1TB 10k RPM
Dell M7710 - Core i7 2.7GHz / 64GB Ram / AMD FirePro W5170M / Dual 512GB SSDs
Windows 10 64-bit
Message 5 of 12
mollons
in reply to: aparrow
Did you set up IIS to handle windows auth?
There is information on how to do so in the advanced config guides here:
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0206-Autodesk206/0264Advanced_Configuration
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 6 of 12
aparrow
in reply to: mollons
Working on it now. Using this:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15739768&linkID=9261340
Windows 10 64-bit
Message 7 of 12
aparrow
Still not working.
Windows 10 64-bit
Message 8 of 12
mollons
Did you have to make changes to the IIS settings?
Did you run an iisreset on the command prompt after making those changes?
Scott Mollon
Quality Assurance
Autodesk, Inc.
Message 9 of 12
aparrow
I did and rebooted the machine for good measure.
Any logs I can review or other places to look?
Windows 10 64-bit
Message 10 of 12
JamesMcMullen
When you log into the ADMS Console... go to the Server Log and see if there is anything interesting there.  Another location to look would be the IIS logs but I am unsure what would be in there.  The ADMS server log should hopefully have more information on the error.  Also, can both machines see another machine on the domain?  A quick test would be having a network share somewhere and see if they can get to it.  I have had machines that I thought were on a domain when they were not.
-Jim
James McMullen
Principal SQA Eng.
Message 11 of 12
aparrow
in reply to: JamesMcMullen
I am suspecting it's something else. Cannot get to ADMS machine thru network. Going to try and rejoin the Domain.
Windows 10 64-bit
Message 12 of 12
JamesMcMullen
Did the rebind to the domain work?  Also, we really need to make sure the ADMS Console works.
-Jim
James McMullen
Principal SQA Eng.
