Our server experience an unplanned reboot. Once it came but online we were unable to launch the ADMS console. The following meesage is in the event viewer every time you click the icon. The error pops up immediatly once you click the icon. Can anyone help ??
Faulting application name: Connectivity.ADMSConsole.exe, version: 17.0.62.0, time stamp: 0x4f3d5d09 Faulting module name: KERNELBASE.dll, version: 6.1.7601.18015, time stamp: 0x50b8479b Exception code: 0xe0434352 Fault offset: 0x0000000000009e5d Faulting process id: 0x1970 Faulting application start time: 0x01cea424d8f423e8 Faulting application path: D:\Program Files\Autodesk\ADMS Professional 2013\ADMS Console\Connectivity.ADMSConsole.exe Faulting module path: C:\Windows\system32\KERNELBASE.dll Report Id: 1cec344e-1018-11e3-b592-e41f136ba1fc
Hi there,
What is the actual ADMS console error? (Dialog that comes up) - you can try http://crackingthevault.typepad.com/crackingthevault/2013/08/error-when-starting-administration-in-a...
You can also run the "Autodesk Server Diagnostic Tool" available under the Data management install tools. THis will diagnose server config issues.
Not sure if that has been ran yet. I will need to reach out to the Admin . Will post as soon as I find out. Thanks!
I sent the link over to my admin and below is the response...
Looking at that, that doesn’t apply to our issue.
We are running ADMS Console 2013 instead of 2014. I looked in IIS and there’s no AutodeskDMpool. The web application is using the DefaultAppPool and that is started.
we have a help desk ticket open for this issue: CaseNo:08715463
I can see your case and it appears support are engaged with your Admin. I expect they will be able to troubleshoot this issue with the detail supplied.
