I have an issue with Autodesk Vault 2012.
I have a number of files checked out to myself on an old machine that no longer exists as it had major faults with the hard drive.
I have tried remove reservation without any luck, I have also logged in as another Adminstrator without any luck.
The file when I look at it in the Vault explorer shows with a tick but no local copy, I need to be able to get the local copy and r remove the reservation.
Any ideas?
Shaun
Solved by lightcube. Go to Solution.
When you try to remove the reservation while logged in as a user with the Administrator role, what error do you see?
Does anything get logged in the server's vlog?
-Dave
I get the message that I cannot remove the reservation because it is not currently checked out to anyone else.
I assume I get this message because it believes the files are checked out to 'me' but on a different machine
I'm having this exact issue right now in Vault Basic 2020. I had files checked out onto another machine which no longer exists. Now I am unable to checkin files using the same user account (with administrative privileges) from another computer.
I can do a Get with Checkout and my local Vault will download the files locally and show them as both available locally and checked out. But when I try to check in the file, I get this error:
File does not exist:
Path/To/File/on/Old/System/myfile.max
Check In aborted.
I tried to fix this by selecting the file in Vault and choosing File > File Control > Remove Reservation but when I do that, I get this error:
Reservation cannot be removed. 'myfile.max' is not currently checked out by someone else.
So the system won't let me check in the file because I checked it out on another computer, but it won't let me unlock it in Vault because my user already checked it out (on the old computer).
How to solve this?
I found a hacky solution to my particular case. On my new system I created a symbolic link to the old path to the Vault working folder (from old system) to point to the Vault root on the new system.
I ran this command with CMD (which had to run as Administrator because the old path was under the Users folder):
mklink /d "C:/Users/Shawn/Documents/Vault/OldVault" "C:\vault\New Vault"
Obviously, anyone else will need to use their own paths and vault names.
Once I did this, Vault was able to find files in the old paths and now suddenly allows me to check in files.
This is definitely a hack, but at least it worked for me.
