I'm facing an issue with a customer that I'm still able to deal with for the moment but a question came to me through that because I had a similar problem earlier : how can I know the database version in vault ?
Iin his case he's trying to attach an old vault to his freshly installed ADSM 2013 (basic) and he has the message which says :
"The migration of a database from version 17.0.5 to 17.0.4 is not possible" (tranlated as I could from french error message).
His Vault version is 2013 basic which is known as 17.0.61.0.
What is the link between vault version and database version and so how can I know the database version ?
For his problem I suggested to install SP1 then update 1 and 2 for vault 2013 SP1 and check after each update. It worked after update 2 (if it can help anyone, but this I remind you that it's not my original question 😄 ).
The backup was from 2013 SP1, and he is trying to restore to 2013 RTM.
The fix is to install SP1 on his freshly installed 2013.
There is no link between the product version and the product schema version, atlhough since 2013 they at least have the same major version number. But there is much more to compability than the product schema version.
Two Web-service methods in the KnowledgeVaultService are available to determining whether or not a vault database is compatible with a server (GetSiteCompatibilityWithKnowledgeMaster and GetSiteCompatibilityWithKnowledgeVault).
-Dave
Hi Dave
can you tell me more about these methods please ? I think it could help me as a reseller.
It is part of the Vault SDK, which can be found it in the "SDK" folder under your ADMS install location.
A search for "SDK" in the Vault Wiki turns up this page, which is a good starting point for developers:
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-F21E7DD6-39E9-473C-84BB-3446BCAFCCC0
If you have any specific questions, the Vault.Customization forum would be more appropriate than this forum.
The methods I mentioned are what Vault uses to determine compatibility when a backup is restored or a vault is attached, so they were implemented with those workflows in mind.
-Dave
OK so there's no easy way to know. Thanks for the answer, maybe I'll find motivation to go further one day (when I'll have the problem again probably).
