I have a Client (Inventor) and Server Vault (2015) installed on seperate computers.
I only can login to the Server when disabeling the FireWall on the server. I know this is not a good thing. So how can I configure the FireWall so that is is safe while I can login into the Vault from Inventor?
The Vault server is running on Windows 7 Ultimate (64 bit). The Client (Inventor) is running on Windows 7 Home (64 bits).
Solved by mandalt. Go to Solution.
For Windows 7
The same information in available is the follwing URL:
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-D77453BD-68A1-465F-8979-05F21E5A382B
