Is it possible to configure Item Master in Vault Professional 2013 so an assembly which is set Inseparable in Inventor is treated the same way as Purchased? So its only 1 line in a Multi-Level BOM List when item is assiged in Item Master.
How can I add Inseparable in the Item Master to begin with? Its only part, assembly and purchased as standard!
Thanks in advance and Happy Weekend š
Not exactly sure what you want but do you mean with 1 line only 1 level in the BOM? If yes you need to disable structured BOM in the assembly BOM inside Inventor
