Could please somebody share the name of config file where Vault Explorer keeps setting used for renaming files.
I mean those radiobuttons for prefix, suffix and their values.
I want there be my default suffix instead of prefix "New".
I'm not aware of any place in Vault Client where you can set these by default. Good Idea Station suggestion?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Not that I am aware of. If there is a setting for this, I've never come across it.
Chris Benner
Right... but you can easily change it in the rename tool at the time though. Or use a file naming scheme (Workgroup & Pro).
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
@Maxim-CADman77 wrote:
Thank you, but I don't feel like doing something each time.
I just want to have things done.
Life isn't like that unfortunately. It would be nice if it was for a while, but then I think it would get boring quite quickly. Or we would all end up like the humans in Wall-E.
Scott Moyse
There is no way to set another file naming scheme as default, right?
i am pretty sure i found a registry hack/edit for this once, but now i cant find it anymore. Anyone know of something like that?
I see that its still under review in Vault Ideas; http://forums.autodesk.com/t5/vault-ideas/vault-wishlist-item-get-rid-of-new-from-rename/idi-p/36497...
...and have been for more than 4 years.
