Vault General
Valued Contributor
jhagarty
Message 1 of 14 (970 Views)
Accepted Solution
Get Previous Version & Can't Checkout
970 Views, 13 Replies
05-02-2011 02:25 PM
I wanted to go back to a previous design in Vault Collaboration 2011 so I chose the version I wanted in Vault and did a Get to copy to my local drive.  I can't checkout any of the files that no longer match the current revision in the Vault.  The checkout option is greyed out.  Any idea what need to do to get this checked back into Vault?
Distinguished Contributor
csmac2004
Message 2 of 14 (960 Views)
Re: Get Previous Version & Can't Checkout
05-02-2011 03:40 PM in reply to: jhagarty
This is the process I use to get a previous version:
  1. Find the version in Vault, right click on it and select "Open"
  2. Go back to Vault, right click on the file and select "Get/Checkout"
  3. Check the box to check out the file BUT also expand the box and UNCHECK the option to Download Files
  4. Go back to Inventor, switch to the Vault browser and refresh.
  5. Save the file and continue working as normal
Let me know if this doesn't work. The key here is to make sure you do not download a new file when doing the Get/Checkout from Vault so it doesn't overwrite the old version you just opened!
Scott MacDonald
Inventor 2013 Product Design Suite
Vault Professional 2013
Windows7 x64
Autodesk Inventor Certified Professional
Valued Contributor
Barvas11
Message 3 of 14 (656 Views)
03-05-2013 08:34 AM in reply to: jhagarty
Useless answer. Doesn't work!
csmac2004
Message 4 of 14 (652 Views)
03-05-2013 08:51 AM in reply to: Barvas11
Useless reply then... You did it wrong.
Scott MacDonald
Windows7 x64
Employee
matt.smith
Message 5 of 14 (629 Views)
03-06-2013 06:57 AM in reply to: Barvas11
The steps csmac2004 listed are correct--you want to get the old version in your workspace and checkout the file (without changing what is in your workspace). Then, check-in from Inventor as usual.
What does "Doesn't work!" mean?  What part of the steps don't work for you?
- Matt
*Expert Elite*
cbenner
Message 6 of 14 (548 Views)
04-11-2013 07:10 AM in reply to: matt.smith
I've been playing with this in an attempt to help another user.  I don't normally deal with this situation.  I've tried reproducing the steps listed above, and when I refresh the file in Inventor, it checks out as "Read Only", and I can't save.  It's also replacing the drawing with a different version, even though I have unchecked the "download" box.  I have tried this with both released and unreleased bias with the same results.  I must be missing one step somewhere.  Any ideas?
BTW, I did not think it was a useless answer.  :smileywink:
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
csmac2004
Message 7 of 14 (542 Views)
04-11-2013 07:44 AM in reply to: cbenner
I wonder, if these steps aren't working, maybe instead of refreshing (step 4) try closing the file and re-opening it? You would still have the old version locally (due to step 1), and if steps 2 & 3 were OK then you would still have it checked out. That might "kick" the Inventor/Vault connection into gear, if you know what I mean?
Scott MacDonald
Windows7 x64
*Expert Elite*
cbenner
Message 8 of 14 (540 Views)
04-11-2013 07:46 AM in reply to: csmac2004
I'll try it... stand by.
ChrisB
*Expert Elite*
cbenner
Message 9 of 14 (539 Views)
04-11-2013 07:51 AM in reply to: csmac2004
That seems to be working.  Seems odd to have to do that, but I'm not going to knock success.  :smileyvery-happy:
 Thanks for the quick answer.  I'll put the other user onto this thread, hopefully it will solve his problem as well.
ChrisB
Employee
matt.smith
Message 10 of 14 (529 Views)
04-11-2013 07:55 AM in reply to: cbenner
It might be that when you do a checkout and *don't* download files that it doesn't remove the read-only from the file (and I'm not sure whether that is correct or not).
However, a colleague of mine recommended that we change the order a bit:
1. Do the Get/Checkout of the file(s) first (i.e. download and checkout the *latest*).  This will get the file checked out as well make them non-readonly.
2. Now do a Get of the file(s) and choose the version you want to revert to.  The files are already checked out, so this operation is just to get the historical version on disk.  I assume that doing the download only here will not set them to readonly.
What concerns me is that you are saying in your steps that you choose *not* to download, and that that step is still downloading some of the related documents.  That one, I can't explain.  You might want to start a support case on that.
Let me know how it goes,
- Matt
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
