I wanted to go back to a previous design in Vault Collaboration 2011 so I chose the version I wanted in Vault and did a Get to copy to my local drive. I can't checkout any of the files that no longer match the current revision in the Vault. The checkout option is greyed out. Any idea what need to do to get this checked back into Vault?
Solved by matt.smith. Go to Solution.
Solved by csmac2004. Go to Solution.
This is the process I use to get a previous version:
Let me know if this doesn't work. The key here is to make sure you do not download a new file when doing the Get/Checkout from Vault so it doesn't overwrite the old version you just opened!
Useless reply then... You did it wrong.
The steps csmac2004 listed are correct--you want to get the old version in your workspace and checkout the file (without changing what is in your workspace). Then, check-in from Inventor as usual.
What does "Doesn't work!" mean? What part of the steps don't work for you?
- Matt
I've been playing with this in an attempt to help another user. I don't normally deal with this situation. I've tried reproducing the steps listed above, and when I refresh the file in Inventor, it checks out as "Read Only", and I can't save. It's also replacing the drawing with a different version, even though I have unchecked the "download" box. I have tried this with both released and unreleased bias with the same results. I must be missing one step somewhere. Any ideas?
BTW, I did not think it was a useless answer.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I wonder, if these steps aren't working, maybe instead of refreshing (step 4) try closing the file and re-opening it? You would still have the old version locally (due to step 1), and if steps 2 & 3 were OK then you would still have it checked out. That might "kick" the Inventor/Vault connection into gear, if you know what I mean?
I'll try it... stand by.
Chris Benner
That seems to be working. Seems odd to have to do that, but I'm not going to knock success.
Thanks for the quick answer. I'll put the other user onto this thread, hopefully it will solve his problem as well.
Chris Benner
It might be that when you do a checkout and *don't* download files that it doesn't remove the read-only from the file (and I'm not sure whether that is correct or not).
However, a colleague of mine recommended that we change the order a bit:
1. Do the Get/Checkout of the file(s) first (i.e. download and checkout the *latest*). This will get the file checked out as well make them non-readonly.
2. Now do a Get of the file(s) and choose the version you want to revert to. The files are already checked out, so this operation is just to get the historical version on disk. I assume that doing the download only here will not set them to readonly.
What concerns me is that you are saying in your steps that you choose *not* to download, and that that step is still downloading some of the related documents. That one, I can't explain. You might want to start a support case on that.
Let me know how it goes,
- Matt
Matt...
That worked also. But in your second step where you said "Get" the older version, after checking out the latest? I think you meant to say "Open" the older version? Vault then warns that you have a newer version of the file checked out, do you want to overwrite with data from the Vault? And you say yes, to open the older version already checked out. Checking it back in then replaces the latest version, with the older one you selected with no read only issues.
Both methods seem to work, though I think this one may seem a bit cleaner and with fewer steps?
Chris Benner
Sounds right.
However, I was referring to just getting the right files on disk and getting the right checked out status independent of Inventor. So, it should be able to work without using "Open" from Vault. "Open" from Vault is problematic in that it *always* downloads files and it *always* gathers dependents with hard-coded settings. By doing a "Get" (rather than open), and have more control over the relationship gathering settings (i.e. do you care about children, do you care about parents, and should it be release biased or not).
Does that make sense, or is there a step in my description that doesn't work properly which made you choose the "Open" approach instead?
Once you have everything right on disk, you could then proceed to open in Inventor and do the check-in.
Nope... just didn't have my head on straight. Your workflow is correct, and works without having to open from Vault. I like it. Thank you Matt!
Chris Benner
I like the re-order much better, thanks Matt! I'll let my team know as well to make sure they avoid the same issues.
