Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Get / Checkout dialog using VDF AcquireFiles in Vault 2014
2 REPLIES 2
spidi444
438 Views, 2 Replies
I have a problem with showing dialog for downloading files using
public static AcquireFilesResults Autodesk.DataManagement.Client.Framework.Vault.Forms.Library.AcquireFiles(ProgressAcquireFilesSettings settings) method.
I am just setting a file to be acquired in ProgressAcquireFilesSettings, but dialog appears only in "LIght GUI" mode (http://wikihelp.autodesk.com/Vault/enu/Help/Help/0378-Develope378/0379-Vault_De379/0380-VDF_Feat380/...
How to show it in "Full GUI" mode?
Mike
2 REPLIES 2
Senthil_Kumar
in reply to: spidi444
Mike,
Can you please post this issue in Vault Customization forum at http://forums.autodesk.com/t5/Autodesk-Vault-Customization/bd-p/301 ?
Senthil
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Redmond.D
in reply to: Senthil_Kumar
The quick answer is that you want to use the InteractiveAcquireFileSettings.  You can find some sample code in this blog article.
Doug Redmond
Software Engineer
Autodesk, Inc.
