Well. I have received some feedback from experts and I am passing it here for your consideration.
1. Search for iam based on the following Criteria.
"Comment contains Move"
2. Select the assembly and click "Go to folder"
3. Click "Uses" tab and select a IPT that was moved from “folder2 “ to “folder1”.
4. RMB on the IPT and choose "Go to folder" - Now you will be able to see "Folder2".
5. Select all the files in the folder and move them back to "Folder1"
I am sorry I do not have a better suggestion at this moment. However, I understand the complications involved with this and I will definitely pass it to Product Designers for future consideration.
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
