ok i will explain the scenerio first then the question.
i have a part, just a simple square. i save and check it into vault
i start a new part and derive the first part into this. save and check it in.
i start a new drawing of the 2nd part(which is just a derived part of the 1st part) and save and check it in.
now the question.
if i make a change to the very first part, save and check it into vault then look at the drawing. Is there anyway by just looking at the drawing(pretend i didnt know i made any changes) to be notified that this drawing is not up to date?
thanks for any and all help!
Joe
Solved by Senthil_Kumar. Go to Solution.
Hi Joe,
Yes. In the Vault Client when you view the drawing we show a warning like below. Hope this helps.
