Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
File that Vault Client uses for publishing .dwf files
6 REPLIES 6
hbohm
362 Views, 6 Replies
Can anyone tell me what file or process Vault Client uses to publish internal .DWF files? I have found that when I do not have DWG TrueView installed, Vault Client cannot publish DWF files via the Update button. Any insight on the matter is much appreciated!
6 REPLIES 6
in reply to: hbohm
DWF publishing is done using the integration (in the background) between Vault and Trueview.
hbohm
Ok thanks for the quick response. Do you know of a way around this? I would like to remove TrueView from the equation altogether if possible. TrueView has always created file association problems with my AutoCAD Electrical.
Richard.Rankin
in reply to: hbohm
Currently, Vault will only use TrueView to publish DWF visualization file.
I am more concerned to get to the root cause of this issue though. I am creating a Support case directly with you. There will be some questions I need to ask you offline but I do intend to get back to this thread with an update.
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
hbohm
in reply to: Richard.Rankin
Sounds great, thank you Richard!
Tags (1)
r.smith1
in reply to: hbohm
Hi Holden, It appears that installing the 64 bit version of TrueView 2012 fixed your issue.  Please let us know if the issue reappears.
Ron Smith
New Product Introduction Manager
scottmoyse
in reply to: r.smith1
doesn't the vault client also use Inventor in the background when creating DWF files from Inventor Files? or is Trueview only used to create DWF's of DWG files?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
