When you try to migrate main vault, an error
Libraries migrated without problems. What could be the reason?
Found such a problem, but there is no particular decision.
Vault Server 2014 to 2015 database migration fails
I think the resolution of this type of error is to open a tech support case. There is no one particular cause of this kind of error, it is unique to each case. A tech support case will get you idividualized support that is beyond what can probably be provided here in the forums.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
AFAIK case opened gives no guarantee to have problem fixed by Autodesk in more-or-less timely fashion.
Lets face the truth - Autodesk does use dirty tricks quite often.
Some cases Autodesk closes with statement "there is no solution in current release" which declared in support agreement as a sort of solution!
Returning to this particular issue:
Case opened, three working weeks have passed. I don't see much sence for case opener to wait reaction from techsupport any longer.
I'd rather collect some customer ideas and try to implement most perspective of them.
For me it seems like there is something in database that is not used anymore but present in some cross reference tables.
Does anybody know ways to initiate some self-maintanece for such cases?
We have a Hotfix i process for this issue, in ashort time you should be able to download a Hotfix for it.
