I created an utility to export the list of all the files in Vault to Excel. Please find the attachment and refer readme for more information.
Hope that helps.
Madhan
Thanks for the feedback. From the error message, it appears to me that there is an issue with initializing excel application. Could you please let me know if the other users have the same version of excel that you have?
Perhaps, I could try modifying the utility to export to txt file so that anyone can just drag and drop the TXT file in Excel application to see the content.
Madhan
Well.. Thank you for the update and here is the new utility that would export the File list to TXT.
Hope that helps.
Madhan.
Trying to get this to work with Autodesk Vault Professional 2011 Update 2 and it keeps erroring out when I try to generate the list.
"Error! Please verify the Log In credentials.. or enter a valid Report Path.."
I am 110% positive that my log in credentials and report path are valid. Is there any way you can get this to work for Vault 2011?
Thanks for your help and time.
-Matt
Disregard this question. The reporting tool can be used in the Vault to create a clean list of ALL files in the Vault.
Advanced Find
Report
File Table.RDCL
Export to XLS
-Matt
Hellow Madhan,
We do not have productstream, just Vault 2011. I am trying to use your excel output script ("Export Files List to Excel.exe") but I keep getting following error. (See image)
I don't think I am using wrong credentials.
With this being an old thread, and there has not been any responses from Autodesk on this, I am hoping there is a more up to date application of this program. We are looking to upgrade to 2015 soon and I am getting the same error as shown in the last couple of postings.
Some feedback from Autodesk would be greatly appreciated in this thread.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
