Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Establish a Lifecycle??
1 REPLY 1
PENengr
283 Views, 1 Reply
We've got parts that we cannot change because they don't have a lifecycle.  How do you establish a lifecycle?
P.S. - These were parts created long before we had Vault. Thanks, Greg
Dell T3500
Intel Xenon CPU
15 MB RAM
64-bit operating system
NVIDIA Quadro 5000
1 REPLY 1
Cadmanto
in reply to: PENengr
Greg,
Are you an administrator to the vault?
What version of vault are you using?
This is where you typically create/maintain lifecycles.
It also should not matter that these parts were created prior to vault.
Do you have any lifecycles established?
When we implimented vault we had a lot of files created.  We had to create the lifecycles first, but even with that said, if you create them later, they still should show up.  I am using 2012 workgroup.
If you could provide what cycles you dosee and what they look like with these particular files that would be helpful.
Another thing to keep in mind is once the life cycles are created, you have to go into each one and establish the details for each.  Here is where your issue may be.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
