Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error shrinking database
3 REPLIES 3
jprizzo
486 Views, 3 Replies
In our backup script, I am using the sql statement recommended on this
newsgroup for shrinking a database:
osql -E -S ".\AutodeskVault" -Q "USE Vault DBCC SHRINKDATABASE(Vault, 10)"
In reviewing our backup logs, I noticed the following error message:
Cannot shrink log file 2 (Vault_log) because all logical log files are in
use.
As a result, we have log files that have grown to be much larger than the
databases themselves. I googled this error message & it seems that I need
to backup the log, but I am hesitant to perform any kind of backup
independent of the ADMS backup utility. Does anybody have a recommendation
of how to get around this error message and safely shrink a database in my
backup script?
Jon
3 REPLIES 3
in reply to: jprizzo
Is the Vault database is in "Simple" recovery mode?
If not set the recovery mode to Simple. You can do this through the SQL Server
Management Studio. Select the Vault database and right click select properties.
In the database properties go to Options and then  set recovery model to
simple.
newsgroup for shrinking a database: osql -E -S ".\AutodeskVault" -Q "USE Vault
DBCC SHRINKDATABASE(Vault, 10)" In reviewing our backup logs, I noticed the
following error message: Cannot shrink log file 2 (Vault_log) because all
logical log files are in use. As a result, we have log files that have grown
to be much larger than the databases themselves. I googled this error message
& it seems that I need to backup the log, but I am hesitant to perform any
kind of backup independent of the ADMS backup utility. Does anybody have a
recommendation of how to get around this error message and safely shrink a
database in my backup script? Jon
It was set to the way Vault created them -
Full.  I set them to simple & I will have to wait until tomorrow to see
if the shrink is successful during tonight's backup.  I have to ask,
though.  Why doesn't Vault create it's databases this way
automatically?
mode? If not set the recovery mode to Simple. You can do this through the SQL
Server Management Studio. Select the Vault database and right click select
properties. In the database properties go to Options and then  set
recovery model to simple.
Vault DBCC SHRINKDATABASE(Vault, 10)" In reviewing our backup logs, I
noticed the following error message: Cannot shrink log file 2 (Vault_log)
because all logical log files are in use. As a result, we have log files
that have grown to be much larger than the databases themselves. I googled
this error message & it seems that I need to backup the log, but I am
hesitant to perform any kind of backup independent of the ADMS backup
utility. Does anybody have a recommendation of how to get around this error
message and safely shrink a database in my backup script?
Jon
From Vault 2009 onwards when you create a new Vault
the database will be in simple recovery mode. Any database that is migrating
from previous release to Vault 2009 will also have the recovery model set to
simple.
Which version of Vault are you using?
"Jon Rizzo" <jrizzo at langan dot com> wrote in message
href="news:6087114@discussion.autodesk.com">news:6087114@discussion.autodesk.com
see if the shrink is successful during tonight's backup.  I have to ask,
automatically?
SQL Server Management Studio. Select the Vault database and right click
select properties. In the database properties go to Options and then
set recovery model to simple.
error message and safely shrink a database in my backup script?
Jon
