Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error " The specified Path , File name. or Both are too long
4 REPLIES 4
1287 Views, 4 Replies
Hello ,
I am getting an error message, "The specified path, File name , or both are too long"
 When I try to check out a document, I have already changed the Temp Folder to C:\Temp to reduce the path length  but still this has not resolved the problem,
Please help urgently as this is preventing from checking out any document,
Regards
Prashant
4 REPLIES 4
jackywen
Hello Prashant,
Try to right mouse click the vault folder where the file resides. In the properties dialog, you can change the Working Folder to a windows folder with proper length for this vault folder. See if that works or not.
Jacky
in reply to: jackywen
Yes it worked,
Thank you
With path too long error I use an alternative tool "Long Path Tool" a guaranteed fast and easy fix .
It is really true that "Long Path Tool" is the best Tool for fixing this type of problem
