Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error "An Item with the same key has already been added"
28 REPLIES 28
Message 1 of 29
spascual
9375 Views, 28 Replies
Hi Sirs,
Any sugestion about this error.
VM210 SP1
Regards
28 REPLIES 28
Message 21 of 29
mollons
in reply to: spascual
Are the ipts (old and new) in the same file category in the Vault?
If one is assigned to a different category they could have different properties assigned to them.
I was only giving another data point, that at least one cause of this problem was solved in Vault 2011.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 22 of 29
spascual
in reply to: mollons
Yes, old an new IPT are in the same category. Now we are not using categories for files (default BASE).
Message 23 of 29
mollons
The best thing would be to contact Product Support, as they can work with you much more closely to try to figure out the problem. They can do a web session with you to see your environment and have the necessary legal forms if you wish to send a dataset to us to investigate the issue further.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Message 24 of 29
spascual
Thanks, I will try for twice.
Regards
Message 25 of 29
spascual
Hi sirs, please,
We need to speak with an authentical product expert that knows exactly what is happenning when a file is assigned to an item.
Properties, web pages, registers,....
I think that in support can response to a common issues.
Message 26 of 29
cmcconnell
We saw this error on Vault Pro 2011 today FWIW...
Mechanix Design Solutions inc.
Message 27 of 29
spascual
Hi sirs, support has worked
In my case, we have two custom properties that was making system runs bad.
One of them "GRUPO", an the other, the same but with blank space before it (human mistake) " GRUPO".
Although " GRUPO" is not active and mapped...???????
We have deleted it on the files affected and seems runs again well.
Thankyou very very much
Regards
Message 28 of 29
Maarten65
I can report we have this issue today while using Vault Pro 2016 and Inventor 2016.
An article is published at Autodesk Knowledge Network
My vendor is contacted to get an update of the status.
Maarten Weers
Technical Specialist CAD - EMEA
Parker Hannifin
Oldenzaal - The Netherlands
Inventor Pro 2019 - Vault Professional 2019 - Windows 10 64 bit -
Message 29 of 29
CHRISTH
in reply to: Maarten65
Yesterday plotting was fine using batch plot, but today this issue has popped up and there has been little or no changes to the parts or drawings involved.  I know there is a workaround but workarounds are not fixes.
I am using IV2019.4 with the latest Vault Server.
There must be an easy way of fixing the files.
iv12(sp2) w7(6.1 SP1) 16gb ram NIVIDA
