Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error during installing inventor pro 2014
9 REPLIES 9
Message 1 of 10
572 Views, 9 Replies
hello,
i got errors during installing inventor pro 2014 x64
its appread 3 times ..
"ExcelVaultAddin2007"
"PowerpointVaultAddin2007"
"WordVaultAddin2007"
and finally ..
what i must do now ?
9 REPLIES 9
Message 2 of 10
jessica.t
Hello Ahmed!
Will you please try this solution to see if it resolves your error? This solution may also be helpful! Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. If not, please respond to this post with further details. Thank you!
Jessica Thrasher
Message 3 of 10
in reply to: jessica.t
not working .. the same 😞
Message 4 of 10
any suggestion guys .. i tried every thing and still the same problem :((
Message 5 of 10
jessica.t
Hi Ahmed! Thanks for hanging in there, this solution is a lot more in depth and could be more helpful. Let me know!
Jessica Thrasher
Message 6 of 10
i tried every thing possible in this solutin but still not working [ expect Edit Setup.ini, i don`t understand how to did it ]  ..
i also tried programs like CCleaner and Dll-Fixer if the problem from registry but nothing happen
this product the only one who fail
can i copy files manually from source file or some something to my programs file ?
or if it hasn`t effect just skip it and work on inventor without it ?
Message 7 of 10
any one help ?
Message 8 of 10
jessica.t
Hi Ahmed,
Sorry for the late reply! Yes, you can download Vault separately, here is the download link:
http://efulfillment.autodesk.com/SWDLDNET3/2014/INVVAU/DLM/Autodesk_VBC2014_ENU_32-64bit_dlm.sfx.exe...
It will expire in 30 days. Please let me know if you need further assistance! Thank you!
Jessica Thrasher
Message 9 of 10
it`s OK
going to download it and setup ASAP and tell u the result
but i have a small question about activation
i will get my own key for 3 years i think through student account
vault had a separate key different from inventor or i will use the same key when i setup ?
Message 10 of 10
jessica.t
You can use your student serial number but be sure to use the corresponding product key with the product you're activating. Let me know if you have any troubles with it!
Jessica Thrasher
