Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error Message - Vault 2013
52 REPLIES 52
Message 1 of 53
timchr
1991 Views, 52 Replies
My group is starting to see the the message below. How can we fix this? This pops up when we are trying to check in files. IT doesn't happen all the time, but often enough that it's a problem.
52 REPLIES 52
Message 41 of 53
TomAllen
in reply to: DanSingleton
Vault 2013 Basic:
Has there been any progress on this issue? We are experiencing these issues as well.
Lock up on check-in / out_ IIS-Worker Process errors _ VLog- Token 300 etc...
Hotfix or similar?
Thanks in advance.
Tom
Message 42 of 53
DanSingleton
in reply to: TomAllen
Nothing yet... Just struggling through here. Getting lots of pressure to look for viable alternatives at this point.
Message 43 of 53
olearya
Hi Gents,
Please note we have addressed a number of the IIS and 300 issues in the latest vault service pack available here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21017345&linkID=9261341
I would ask that you apply this and monitor any further errors / issues.
Allan
Product Manager
Autodesk, Inc.
Message 44 of 53
timchr
in reply to: olearya
We are still getting the error message. Not as often, but still happening.
Message 45 of 53
olearya
in reply to: timchr
Hi Tim,
If you have applied the patches and you are still seeing issues I would recommend opening a support case with Autodesk to get deeper into this issue.
As noted through this thread there are a number of conditions that cause IIS to overload and fail resulting in loss of connection and these subsequent errors - the updates we released dealt specifically with threadsafe components of our product that were contributing to the overload but there may be other causes specific to each site.
@Tom and Dan - have the updates resolved your issues?
Allan
Product Manager
Autodesk, Inc.
Message 46 of 53
TomAllen
Applied the service pack.
Same as previous post, still happens, just not as often.
Message 47 of 53
olearya
Hi Tom,
We will need to investigate your case further, as suggested we have identified one source of this issue which seems to have alleviated your problems but not resolved it all together - if you haven't already done so please log a support case so we can follow this up.
Allan
Product Manager
Autodesk, Inc.
Message 48 of 53
orbjeff
Disabling content indexing and applying the Vault Server 2013 Service Pack 1 has resolved the issue for the cases we have worked on.
Jeff Johnson
Technical Consultant
MasterGraphics Inc.
Message 49 of 53
timchr
in reply to: orbjeff
You mean the same one we installed on 12/17/2012 that didn't help our problem. I don't mean to sound like an "A....Hole" but it's getting very frustrating going round and round. Also disabling content indexing would limit the search capabilities in at the user level, correct?
Message 50 of 53
TomAllen
Thank you Jeff.
That is our current configuration, but we have still had issues.
Less often since the service pack though.
Additionally, yesterday afternoon we increased the ASPMaxRequestEntityAllowed and AspBufferingLimit  parameters for IIS6.0 and
 so far
no lock ups today, so we'll see.
Reference: http://support.serverintellect.com/KB/a321/how-to-set-file-uploaddownload-size-limits-in-iis-6.aspx
the script was not correct for our default location of the adsutil.vbs file, but a search for it and then point it..and it worked fine.
Time will tell, I'll report back if it locks up again.
Tom
Message 51 of 53
orbjeff
Disabling content indexing will limit your search results. I can only speak on what I’ve observed with other client installs. In those cases there seemed to be some correlation between checking in new files while content indexing was enabled that caused this error to be thrown.
Typically the sequence of events is as follows:
1.)    Add a new file to Vault (with content indexing enabled)
2.)    Some files go in with no problem
3.)    If not you get a long delay then the target of invocation error appears
4.)    At this point the  IIS Worker Process has crashed on the server
5.)    Next you may receive an error code 0 when you try to add a new file until you perform an IIS Reset on the server.
So does the Vault 2013 Service Pack 1 fix the problem or is it really just a matter of disabling content indexing because it’s not playing nice with some of your files? I'm not sure there is a solid answer yet. I’m curious to know if it fixes your issue though.
Jeff Johnson
MasterGraphics Inc.
Message 52 of 53
loesche1
Hello Vault-fault bothered!
Are there any new findings in solving this annoying issue? We also ran in that IIS-problem after upgrading to Vault 2013... We're no longer able to copy designs of Inventor assemblies in Vault.
Thanks in advance!
Message 53 of 53
olearya
in reply to: loesche1
Hi Gents,
As mentioned previously there appears to be a multitude of triggers for this worker process issue and while we have resolved what appears to be the larger number of cases with the fixes posted here earlier there are some ongoing problems. Some of these have been further resolved by reinstalling the actual ADMS console and reapplying the fix but if you are having issues I would encourage you to reach out to support so they can guide you on next steps and ensure we capture the exact details of your issue.
Allan
Product Manager
Autodesk, Inc.
