In december we migrated from Vault 2012 to 2014, until then the purge-command worked. This morning I wanted to purge some documents from the Vault (Basic 2014). My account in Vault is one with administrator rights, but it still didn't work. I then checked the permissions in the Global Settings in Vault and concluded that the Purge-command should be available to me. Tried purging again, but still Error 303. Then I logged in as Administrator and tried it again, same error.
I stumbled on a message of someone else here, with the same problem.
What's wrong here? Help is greatly appreciated.
Solved by Senthil_Kumar. Go to Solution.
Can you please refer this help for more info on how to enable the purge and also for information related to Purge?
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-36F79FDE-C4C3-453A-B687-127741AADD5B
That's it! Checked the file references of the to purge documents and enabled purge on the Vault Server via ADMS. Thanks a lot!
