Solved by Richard.Rankin. Go to Solution.
OK, Humour me with this please,
What happens if you pull out the network cable from the back of the machine during install then reconnect it afterwards?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I suspect it has something to do with the NIC itself. Maybe the NIC driver needs updating or its one of the settings. If thats the case, its tricky to troubleshoot remotely.
Let us know how it goes.
We have this problem too. Disabling the networkcard did the trick. But, when reboot, the service will not start.
The workaround with the batchfile (http://crackingthevault.typepad.com/crackingthevault/2011/07/error-1920-error-during-vault-server-in...) can help when accessing the server remotely.
I wonder what this service is used for.
Sometimes, when starting the ADMS (with the service started) an error pop-up with te message, could not start job dispatch service.
Our backup script has also a reference to this service (stopping the service and then starting the service to be sure the service is started). Is this still advised/necessary...?
Ok, we faced this & it's solved by unplugging the networkcabel & reconnect it aftre installation.
Now Vault consol doesn't start.we juct doubel clicking its icon & no reply....
Me helped, set up the service starts, as another domain user
(service --> right click on Autodesk Data Management Job Dispatch --> run as -->specific domain user account (user x pass))
and on instalation press Retry button.
alternative little hard procedure!!!
Task Manager and end the installer process, when he show te error window
then
set, in the service starts as a domain user and run manually in service window.
This sollution apply on my virtual training vmware server and it worked
Sorry Screenshot Czech Windows 😉 example only.
