I'm trying to create an x64 Vault Pro 2014 deployment and I'm getting the following Error.
Error 1310. Error writing to file.
See attached screen captures.
I've been created deployments for years and haven't had this error yet. I have full admin permissions and access to this server. Please help figure out why I can't create a deployment.
Server Specs
Intel Xean CPU E5540 @2.53 Ghz (2 proccessors)
Windows Server 2008 SP2 x32
Solved by samuel.seah. Go to Solution.
Hi John,
is it possible to copy the install files locally to discount network issues?
Hi John,
This error comes because the network path + file name is too long. Could you please retry to create the deployment image to a location with a shorter network path length?
Samuel
Samuel,
Thank you very much for help with solving this problem. You are absolutely correct that the network path + filename was too long. The strange thing about this is that the x32 Vault Pro 2014 deployment did not have this issue. Only the x64 deployment did. I move the x64 deployment to a different location with a shorter patch and I shortened the deployment name and my deployment was created successfully.
Thanks again!
