Hello
After installed ts16102141.zip and ts15770173.zip
I'm getting error 109 when editing user property if I edit system properties there's no problem
I've made an experience if I remove mapping to inventor files I can edit the properties but then I lose that mapping because I can't remap the property
In the log file there's nothing about error 109
I have SQL 2008 Standard edition installed
Please Help
Solved by AMadaleno. Go to Solution.
A custom property in Vault with list values would not allow the entry of a non list value
so to fix this problem I mapped other property so that I could enter a non listed value.
After installed the hotfix's it was not possible to edit mappings or mapped properties
the solution was to delete the property I've created to solve the non listed value
to fix the non listed value I installed the ts16158490
Thank's
Hi
I am experiencing the same error but cannot delete the existing property Rev Number. Cannot edit it, cannot map it to system property Revision
All I am trying to do is map system property Revision to Inventor file property Rev Number and unable to do it anymore. I suspect it has something to do with applying latest service packs and/or hotfixes
Any suggestions?
MaxB
I have the exact same issue here...
Any ideas?
I was able to do it before... must be related to an update.I agree with MaxB...
Any help appreciated!
I tried again and I'm unable to modify any properties mapping in the Properties manager of Vault Pro 2011.
I really need a solution. It's a "show stopper" for me right now.
Thanks.
I agree, this issue needs to be resolved ASAP as it makes the Vault property mapping functionality un-usable
I raised a support case with Autodesk, will post here as soon as hotfix/workaround is found
MaxB
Is your version of SQL up to date? SQL 2008 is up to SP3.
Error 109 is found i the log file. Here is what it looks like:
Error: Soap Exception ( mesg-id = 634317226111207649 )
Exception: DatabaseError [109]
Stacktrace:
Server stack trace:
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Core.Services.PropertyService.UpdatePropertyDefinitionInfo(PropertyDefinitionInfo propertyDefInfo)
at Connectivity.Web.Services.PropertyService.UpdatePropertyDefinitionInfo(PropertyDefinition propDef, EntityClassContentSourcePropertyDefinitions[] eClsCtntSrcPropDefs, PropertyConstraint[] constraints, Object[] listValues)
Exception(Inner): The INSERT statement conflicted with the FOREIGN KEY constraint "FK__EntityClassPrope__3F27380A". The conflict occurred in database "Ferneto", table "dbo.ContentSourcePropertyDef".
The statement has been terminated.
Stacktrace(Inner): at Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
at Connectivity.Core.Database.SqlAccess.e(SqlCommand A_0)
at Connectivity.Core.Database.SqlAccess.ExecuteNonQuery(CommandType commandType, String commandText, Int32 commandTimeout, SqlParameter[] commandParameters)
at Connectivity.Core.DataAccess.PropertyDefinitions.a(Int64 A_0, Int64 A_1, Int64[] A_2, String[] A_3, MappingTypeEnum[] A_4, Int32[] A_5, MappingDirectionEnum[] A_6, Boolean[] A_7, Boolean A_8)
at Connectivity.Core.BusinessLogic.PropertiesBL.a(Int64 A_0, Int64 A_1, ContentSourcePropertyDefinition[] A_2, MappingTypeEnum[] A_3, Int32[] A_4, MappingDirectionEnum[] A_5, Boolean[] A_6, Boolean A_7)
at Connectivity.Core.BusinessLogic.PropertiesBL.a(PropertyDefinition A_0, List`1 A_1)
at Connectivity.Core.BusinessLogic.PropertiesBL.UpdatePropertyDefinitionInfo(PropertyDefinitionInfo propDefInfo, PropDefInfoDataEnum propDefInfoData)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
I have had luck in the past resolving error 109 by detaching / re-attaching the data base. Also by restoring a previous backup of the Vault.
