Can someone please help me figure this out?
Just updated to 2014 Inventor Pro and 2014 vault last week. Everything worked fine till this morning. Now we can’t check in any drawings to Vault. The assembly and part files still check in fine. We have tried to check in 10 different drawing files on 10 different computers and it still didn’t work. I have tried to check it in every different way I could think of and nothing. Every time I try to check a drawing in Inventor freezes up.
I have made a test drawing with nothing attached to it, no code, no embedded files, nothing and it still will not let us check it in.
Please help me, Obi-Wan Kenobi; you're my only hope…
JD
Since this was an upgrade, I assume you have older drawings already in your Vault? Can you check these out with no problem? Check them back in?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I found the solution on a different post. Thanks for your quick response.
Here is the solution:
1. On all ADMS’, examine the content of the ‘C:\Windows\Temp’ directory for ‘UNDDACAD.ac$’.
2. Check the file date. If it is much older than the installation date (or if you want to test this), proceed…
3. Invoke IISRESET /STOP.
4. Move ‘UNDDACAD.ac$’ out of the ‘C:\Windows\Temp’ directory.
5. Invoke IISRESET /START.
6. Test DWG check in.
a. The check in will generate a current version of ‘UNDDACAD.ac$’ (you may want to verify the new date).
