Hey everyone i hope you can help, i have a problem installing 3ds max 2013 that i can see a lot of other people have had and have tried sooo many of the remidies to no avail. Im hoping someone could shed some light on my personal 1603 error, it would be soooooo appreciated! heres the log...
I have highlighted the lines with the failieres, i cant seem to see what it could be!?
2013/8/13:08:47:57 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:08:47:57 Joe JOES-PC Launch
2013/8/13:08:48:21 Joe JOES-PC === Setup ended ===
2013/8/13:08:48:03 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:08:48:03 Joe JOES-PC Launch
2013/8/13:08:48:24 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:08:58:27 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:08:58:33 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:08:59:17 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:08:59:21 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:08:59:22 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:09:02:46 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:09:02:46 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:09:03:39 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:09:03:39 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:09:04:43 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:09:04:43 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:09:06:26 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:09:06:28 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AIFA3E.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:09:06:46 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:09:06:56 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:09:07:05 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:09:07:55 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:09:07:55 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:09:07:57 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:09:16:48 Joe JOES-PC === Setup ended ===
2013/8/13:09:38:34 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:09:38:34 Joe JOES-PC Launch
2013/8/13:09:38:51 Joe JOES-PC === Setup ended ===
2013/8/13:09:38:39 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:09:38:39 Joe JOES-PC Launch
2013/8/13:09:38:53 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:09:43:23 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:09:43:25 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:09:44:07 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:09:44:44 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:09:45:12 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/13:09:45:31 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/13:09:45:31 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:09:45:40 Joe JOES-PC === Setup ended ===
2013/8/13:09:55:05 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:09:55:05 Joe JOES-PC Launch
2013/8/13:09:55:16 Joe JOES-PC === Setup ended ===
2013/8/13:09:55:08 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:09:55:08 Joe JOES-PC Launch
2013/8/13:09:55:17 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:09:55:42 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:09:55:44 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:09:56:24 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:09:56:27 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:09:57:05 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:09:59:46 Joe JOES-PC Install DirectX® Runtime Failed Failure is ignored, Result=-9
2013/8/13:09:59:46 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:00:12 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:10:00:12 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:01:06 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:10:01:06 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:02:14 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:10:02:16 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AI422E.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:02:29 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:10:02:36 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:10:02:45 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:10:03:25 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:10:03:29 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:10:12:28 Joe JOES-PC === Setup ended ===
2013/8/13:10:24:06 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:10:24:06 Joe JOES-PC Launch
2013/8/13:10:24:15 Joe JOES-PC === Setup ended ===
2013/8/13:10:24:09 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:10:24:09 Joe JOES-PC Launch
2013/8/13:10:24:16 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:10:24:18 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:10:24:20 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:10:25:05 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:10:25:36 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:10:25:36 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/13:10:25:46 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/13:10:25:46 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/8/13:10:25:59 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/8/13:10:25:59 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:10:27:43 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:10:27:43 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:28:00 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:10:28:00 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:28:40 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:10:28:40 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:29:46 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:10:29:47 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AID2BA.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:30:01 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:10:30:09 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:10:30:16 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:10:30:50 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:10:30:50 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:10:30:50 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/13:10:30:50 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/13:10:30:52 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:10:32:53 Joe JOES-PC === Setup ended ===
2013/8/13:10:39:33 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:10:39:33 Joe JOES-PC Launch
2013/8/13:10:39:45 Joe JOES-PC === Setup ended ===
2013/8/13:10:39:36 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:10:39:36 Joe JOES-PC Launch
2013/8/13:10:39:46 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:10:39:51 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:10:39:51 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:10:40:17 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:10:40:17 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:10:40:58 Joe JOES-PC PageOpen BeginDeploymentDialog
2013/8/13:10:41:04 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:10:41:06 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:10:41:06 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:10:41:22 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:10:41:22 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:10:41:25 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:10:41:29 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:10:42:04 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:10:42:18 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:10:42:18 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:10:44:35 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:10:44:35 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:45:11 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:10:45:11 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:45:49 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:10:45:49 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:46:55 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:10:46:57 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AIF892.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:10:47:10 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:10:47:14 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:10:47:22 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:10:47:58 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:10:47:58 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:10:48:00 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:10:50:00 Joe JOES-PC === Setup ended ===
2013/8/13:11:07:32 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:11:07:32 Joe JOES-PC Launch
2013/8/13:11:07:45 Joe JOES-PC === Setup ended ===
2013/8/13:11:07:36 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:11:07:36 Joe JOES-PC Launch
2013/8/13:11:07:46 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:11:09:56 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:11:09:58 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:11:10:42 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:11:10:57 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:11:10:58 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/13:11:11:10 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/13:11:11:10 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/8/13:11:11:23 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/8/13:11:11:23 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:11:13:15 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:11:13:15 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:13:38 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:11:13:38 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:14:27 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:11:14:27 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:16:29 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:11:16:33 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AIC7B1.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:16:51 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:11:17:00 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:11:17:11 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:11:17:57 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:11:17:58 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:11:17:58 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/13:11:17:58 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/13:11:18:01 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:11:20:09 Joe JOES-PC === Setup ended ===
2013/8/13:11:32:06 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:11:32:06 Joe JOES-PC Launch
2013/8/13:11:32:16 Joe JOES-PC === Setup ended ===
2013/8/13:11:32:08 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:11:32:08 Joe JOES-PC Launch
2013/8/13:11:32:16 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:11:32:58 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:11:33:03 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:11:33:46 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:11:34:11 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:11:34:11 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/13:11:34:24 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/13:11:34:24 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/8/13:11:34:41 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/8/13:11:34:41 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:11:38:23 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:11:38:23 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:38:40 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:11:38:40 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:39:31 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:11:39:31 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:40:56 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:11:41:05 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AI4328.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:11:41:16 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:11:41:19 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:11:41:24 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:11:41:54 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:11:41:54 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:11:41:54 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/13:11:41:54 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/13:11:41:58 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:11:55:04 Joe JOES-PC === Setup ended ===
2013/8/13:13:26:17 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:13:26:17 Joe JOES-PC Launch
2013/8/13:13:26:17 Joe JOES-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/8/13:13:28:52 Joe JOES-PC === Setup ended ===
2013/8/13:13:36:46 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:13:36:46 Joe JOES-PC Launch
2013/8/13:13:36:57 Joe JOES-PC === Setup ended ===
2013/8/13:13:36:49 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:13:36:49 Joe JOES-PC Launch
2013/8/13:13:36:57 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:13:37:01 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:13:37:06 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:13:37:46 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:13:38:36 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:13:38:36 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:13:40:33 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:13:40:33 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:13:41:00 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:13:41:00 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:13:41:13 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:13:41:14 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:13:41:24 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:13:41:25 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AI6653.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:13:41:34 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:13:41:40 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:13:41:49 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:13:42:25 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:13:42:25 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:13:42:26 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:13:45:31 Joe JOES-PC === Setup ended ===
2013/8/13:14:00:03 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:14:00:03 Joe JOES-PC Launch
2013/8/13:14:00:13 Joe JOES-PC === Setup ended ===
2013/8/13:14:00:08 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:14:00:08 Joe JOES-PC Launch
2013/8/13:14:00:13 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:14:00:32 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:14:00:36 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:14:01:15 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:14:01:34 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:14:01:34 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/8/13:14:01:45 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/8/13:14:01:45 Joe JOES-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/8/13:14:01:59 Joe JOES-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/8/13:14:01:59 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:14:03:59 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:14:03:59 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:04:25 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:14:04:25 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:04:38 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:14:04:38 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:04:49 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:14:04:50 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AIB9A1.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:05:01 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:14:05:07 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:14:05:15 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:14:05:40 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:14:05:40 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:14:05:40 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/13:14:05:40 Joe JOES-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/8/13:14:05:41 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:14:09:04 Joe JOES-PC === Setup ended ===
2013/8/13:14:15:52 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:14:15:52 Joe JOES-PC Launch
2013/8/13:14:15:59 Joe JOES-PC === Setup ended ===
2013/8/13:14:15:54 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:14:15:54 Joe JOES-PC Launch
2013/8/13:14:15:59 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:14:16:02 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:14:16:04 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:14:16:47 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:14:17:13 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:14:17:13 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:14:19:52 Joe JOES-PC Install DirectX® Runtime Succeeded
2013/8/13:14:19:52 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:20:14 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:14:20:14 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:20:42 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:14:20:42 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:21:15 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:14:21:16 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AI32F5.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:21:26 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:14:21:32 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:14:21:46 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:14:22:30 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
2013/8/13:14:22:30 Joe JOES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/13:14:22:31 Joe JOES-PC PageOpen InstallCompleteDialog
2013/8/13:14:37:11 Joe JOES-PC === Setup ended ===
2013/8/13:14:45:29 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:14:45:29 Joe JOES-PC Launch
2013/8/13:14:45:37 Joe JOES-PC === Setup ended ===
2013/8/13:14:45:32 Joe JOES-PC === Setup started on JOES-PC by Joe ===
2013/8/13:14:45:32 Joe JOES-PC Launch
2013/8/13:14:45:38 Joe JOES-PC PageOpen LaunchDialog
2013/8/13:14:45:39 Joe JOES-PC PageOpen LicenseDialog
2013/8/13:14:45:44 Joe JOES-PC PageOpen ProductInfoDialog
2013/8/13:14:46:22 Joe JOES-PC PageOpen ProductSelectionDialog2
2013/8/13:14:46:35 Joe JOES-PC PageOpen FullProgressDialog
2013/8/13:14:46:35 Joe JOES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/8/13:14:48:08 Joe JOES-PC Install DirectX® Runtime Failed Failure is ignored, Result=-9
2013/8/13:14:48:08 Joe JOES-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:48:37 Joe JOES-PC Install Autodesk Material Library 2013 Succeeded
2013/8/13:14:48:37 Joe JOES-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:48:56 Joe JOES-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:14:48:56 Joe JOES-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:49:08 Joe JOES-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:14:49:09 Joe JOES-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joe\AppData\Local\Temp\_AI50F1.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/13:14:49:19 Joe JOES-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/8/13:14:49:25 Joe JOES-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/8/13:14:49:37 Joe JOES-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/8/13:14:50:10 Joe JOES-PC Rollback Autodesk Material Library 2013 Succeeded
