Is there a config file somewhere which stores the CAD Add-In and Vault Client dialog and prompt suppression settings? Maybe there are some registry keys which set it?
I want the administrator to make some decisions surrounding standards for dialog suppression, then push them out to the team in some way. I'm mainly interested in the Inventor Add-in and the Vault client at this stage. But it would be useful for the others as well.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Solved by johannes.bauer. Go to Solution.
Hi Scott,
thanks for engaging here with us on the forums.
There is a xml file called
"Applicationpreferences.xml" in e.g. for Inventor here: C:\Users\<username>\AppData\Roaming\Autodesk\Inventor 2015 Vault Addin
you can check there the dialogues and use
<Property Name="Suppressed" Value="True" />
to play around with the settings
If you make them not work any longer, just delete it and it will be recreated on restart of Inventor.
Johannes, that just about covers them all.. Chur Bro!
Scott Moyse
Good to hear it helped.
Have a great day!
