Hello everyone!
Is any best practise of clear File store after database purge.
Example:
I have 6 versions of documents at vault
DOC_1 ... DOC_6
After purge there is only 1 last version is at database, but all 6 files still are at Filestore.
Thanks!
Best Regards
Konstantin Biktimirov
Solved by mikel_martin. Go to Solution.
Solved by smilinger. Go to Solution.
File versions deleted or purged from vault will not be deleted from filestore immediately but periodically - usually on a daily basis. So I don't think you need to worry about this.
I highly recomeend that you NOT try to clean up these files yourself.
The system will do it for you.
