Is there a way to decrement a revision? It doesn't seem so, but maybe by creating a new revision scheme ?
I am looking for a solution because often I accidentally put a file into work in progress whereby Vault increases the revision OR the file somehow got loaded to Vault with the wrong revision and I need to lower it.
Solved by olearya. Go to Solution.
We struggle with this too. Especially, when having to do a quick change or the like. We actually created a custom property called "Revision_Level". This is what we go by rather than the default. Allows us to be extremely flexible, especially when using items. We really didn't have a choice.
Thanks for the feedback, we have captured this requirement but you gents should make sure you go and vote on its importance over on the IdeaStation:
http://forums.autodesk.com/t5/Autodesk-Vault-IdeaStation/Rollback-Revision-Increment/idi-p/3552636
