Dear,
I have problem with function "Defer updates" for Inventor DWG. If I check-in drawing to a Vault with defer updates and after check-out so the defer update has turned off and drawing taking new (last) model version. This behaviour is only for Vault Add-in in Inventor, only for Inventor DWG (I have necessary used Inv DWG).
If I open drawing from Vault Client or local folder so all right.
Please, exist any Hotfixor working procedures for it?
My configuration:
Inventor 2011 SP3 CZ,
Vault Professiona 2011 CZ Update 2 with all hotfix,
Windows 7 CZ
Thank you for your request,
Petr Polivka
Solved by Madhan_T. Go to Solution.
Thank you for reporting this. I will forward this to development.
Madhan
Hello
Was this issue fixed in Inventor 2011, as In Vault 2012 and Inventor 2012 If I select defer updates in the Inventor drawing and check in the file.When I open the drawing again and check out the defer updates is switched off.The only way I can get updates to be defered is when openning the drawing from the Vault to select the option box, the defer updates is already selected, select ok and then open.So Every drawing I open I have to select the options box first.
