This is controlled by the GridState.xml file: C:\Documents and
Settings\\Application Data\Autodesk\ProductStream\Servers\\Vaults\\Objects\GridState.xml. Copy this to each client
machine to standardize the Vault Explorer session.
Another xml I suggest copying is the Working folder setting. Setting this on
each user's workstation can be a tedious process. Go to C:\Documents and
Settings\\Application Data\Autodesk\VaultCommon\Servers\\Vaults\\Objects\WorkingFolders.xml.
Brian Schanen
Autodesk Inventor Certified Expert
Autodesk Manufacturing Solutions Implementation Certifed Expert
MasterGraphics
brian.schanen@masterg.com
"Peter_Dettmer" wrote in message
news:26200632.1109716692611.JavaMail.jive@jiveforum2.autodesk.com...
> Hello:
> I'm having more Users going online with the Vault. I want to copy the
registry settings for my customized views in VE to all the other users.
> The ability to export ones registry settings, sure would be a nice feature
to add on the next release!
> In the meantime, how can I manually copy them to other users, where are
they located, and anything specific to look out for, beside the standard
"Don't mess with the registry" warnings.
> TIA
> Peter Dettmer
> Big Sky Engineering
> peterd@bigskyeng.com
