In learning Vault on the job fairly recently, I have learned from others and discovered myself the following tips & tricks that save time -- especially when copy/designing large assemblies:
G'luck!
- Clara
These tips should be spelled out better in the Vault client. They are essential to using copy design. I would like to add, right click on the main assembly you are copying and choose do not copy library parts. This will keep you from having to manual deselect all these. This used to be default behavior bu they changed it back in 2012 or something for no apparent reason.
Very valid point. Also, very nice touch with the right-click tip you describe. I'm currently on Vault Pro 2014, and this comes up as "Reuse Library Files" in my version.
Thank you!
- Clara
