I'm trying to make a copy of my design in Vault (AutoCAD Electrical 2013 & Vault Pro 2013) and I am getting this error which ends the process.
Any ideas what is causing this or how I should procede? This is the first indication I've seen that the WDP file needs repairing. Or is it telling me it can't repair the new copy? (Version 2) If so, what exactly is this telling me? (See attached image.)
Thanks.
Autocad Electrical designs should be copied using the Electrical application. Not Vault. You can Copy Design right inside of Electrical, and then check it into Vault. The Copy Design feature is very handy, it allows you to decide which drawings in a project you want to copy, or all of them... and also lets you rename them and point to a new location. Look it up in Autocad Electrical under the Project tab.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
