Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Chnge C:/temp to another location in Vault
4 REPLIES 4
528 Views, 4 Replies
While renaming or viewing with DWG viewer Vault Access by default to C:/temp I wanted to change it to some other location. Is it Possible to do the change I am currentley using Vault Basic 2012.
4 REPLIES 4
yuhui.zhang
check following wiki page please
http://wikihelp.autodesk.com/Vault/enu/Community/Tips_and_Tricks/Changing_the_TEMP_Location
Fay Zhang
Software QA Engineer
Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
in reply to: yuhui.zhang
After i modify Connectivity.Vault.exe.Config file vault 2012 is unable to run -- Thanks & Regards Tanveer
yuhui.zhang
Thanks for your feedback, please restore to the orignial one to make sure the application run well first. I tried in 2012 Vault, the trick works fine to me, You may refer to attached screenshot & copy for the reference.
(Note, the copy include the change of temp folder only, other sections from a fresh installation, if you simplely replace yours with it, you may lost your other settings.)
btw, Andy also replied your comments in wiki page, hope both helpful.
Fay Zhang
Data Management
Autodesk, Inc.
Thanks for the reply.
All of these changes in that file doesn't effect in my vault.
