Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Checkin failure
1 REPLY 1
209 Views, 1 Reply
Checkin failure
Hi all,
novice here. New install of Vault 2012. checking in from AutoCAD 2011 64bit & 2012 32bit both on Win7 Pro SP1, same result. Many files have checked in fine. Troubleshooting failures. Reparied xrefs. Network drives are mapped.  Logged out, restart, login...
initiate checkin, chose location, then an information pop-up text box... "Could not checkin. Unable to relocate drawing for checkin."
Is this a user error? Something I did or did not do? Any help would be appreciated.
Thanks in advance,
Steve
1 REPLY 1
KooCheeKit
This could due to no access right to create folder/file in the working folder. i assume the check in of the dwg is from outside working folder base on the error message.
Chee-Kit
Autodesk, Inc.
