If an R13 or Autocad 2007 drawing is checked into Vault using AutoCad 2011 and the Vault add-in, will the drawing still be okay to open in R13? Or will it be saved to Autocad 2011 format?
Thankyou!
Solved by Senthil_Kumar. Go to Solution.
It should retain the format. If you have XREFs repathing of XREFs happen. But otherwise it should retain the file format.
On a safer side keep a copy of it before doing the folder check-in.
