Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Check-in folder in Autocad - does it affect file version?
2 REPLIES 2
jeoffry
316 Views, 2 Replies
If an R13 or Autocad 2007 drawing is checked into Vault using AutoCad 2011 and the Vault add-in, will the drawing still be okay to open in R13?  Or will it be saved to Autocad 2011 format?
Thankyou!
2 REPLIES 2
Senthil_Kumar
in reply to: jeoffry
It should retain the format. If you have XREFs repathing of XREFs happen. But otherwise it should retain the file format.
On a safer side keep a copy of it before doing the folder check-in.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
jeoffry
in reply to: Senthil_Kumar
Thanks Senthil.
I did some tests with the help of this thread and you were right.
